SLCM Replacement
SLCM Replacement
I recently replaced my SLCM on my 2002 XJ8 Vnp with one that had the same VCATS and 008 security codes, my key pads did program correctly, however I still have same problem with my right tail light, it does light one side of the dual filament, also I have no tail lights. Is there any additional programing required? Or any other suggestions anyone may have? Thanks
lzarc1 (09-10-2016)
Thank You Motorcarman; I did the earth ground with no results with my running lights and secondary filament on righlt brake. I also looked at the wiring schematic and it mentions the Body Processor Module in the wiring scheme, do you have any thoughts on this could cause my problem? Thanks Again.
The electrical guide has the module locations and pin-outs in the FRONT MATTER section of the guide.
The preceding page to the actual wiring layout has pin IDs and the function of each pin (input or output and the 'STATE' of the pin) as well as the connectors and their locations.
Many people forget to read that page and just look at the wiring.
bob
bob
Bob Lawless
09-07-2016 07:16 PM
AltaHeights1
09-07-2016 04:49 PM
mikebaker3
09-05-2016 06:40 PM
