Sliding sunroof panel removal
Can anyone explain the procedure for removing the rearmost sunroof panel for retrimming? It looks like it slides off the rear of the tracks after removing the gray rubber plugs, but I'm encountering a spring-like resistance and don't want to break any plastic. Wondering if there are clips that need to be depressed? On my last retrim I had the entire track assembly out of the car and can't recall this aspect. Thanks
Doug Dooren (09-24-2022)
Needed help removing the sunroof's rear sliding panel, and now need help with the install. The spring-loaded arms that pick up the rear panel don't seem to align properly. Here you can see the pin of the arm standing mostly proud of the slot in the panel. After a few inches of travel the arms snap out of the panel. Any direction on what's wrong here? Otherwise the headliner install is complete save the rear glass trim. Has anyone ever installed the rubber gasket for the rear glass and have any tips?
For future reference, you don't want to try bending those arms much as they have a tendency to snap and given the general lack of sunroof part availability, that would be a bad day. People have had better luck bending the shaft that holds that cast arm. I solved this issue by placing a clip over the two pieces to hold them together.
Second That!
It will need to 'tilt' up to remove the larger interior panel because it slides out the opening to the rear.
Then the sliding steel roof panel is removed. (3 screws on each side)
The short interior panel is 'clipped' to the plastic track followers and it comes out the top.
You might need to drop the entire assembly from inside but it will be heavy.
Addicted2boost (09-27-2022)
motorcarman (09-28-2022)
ThosMa
04-02-2021 04:29 PM
caldercay
10-24-2011 10:47 PM
