Slight timing chain rattle at 2500 rpm
Basically there are three tensioner designs: Plastic, plastic with spring assist, and metal. Plastic goes to 01/02, spring assist 02, and metal 03 and up. You have to pull a cam cover to see what you have.
Yes, it is something to worry about. If the secondary chains skip more than a couple of teeth, it will destroy your engine.
Do not start or drive the car until you have it repaired.
Secondary tensioners over here are a $200 DIY, $800 Indy, and $1600 dealer job, not sure about the UK.
Vector
