Something interesting regarding M112
Here is some more good info showing some of the differences between the 2 diffferent roots type versions:
Blower Tech
If you are considering making your own setup, then there are some tips in here too.
However pending on the hp output you are interested in, you should also think about which blower type to choose. The roots TVS is of course much better than the older 5th gen one, but at higher boost levels, the right twin-screw will be even better, and cost about the same as a tvs unit. The work to get either the TVS or Twin-Screw fitted right (so proper intake manifold) is also about the same (asssuming not to much work is needed on the TVS one to make it fit).
Blower Tech
I just thought it was interesting that supposedly Roush is working on the rotor upgrade for the M90. A rotor swap would be easier than trying to make something else fit.
Avos, If i decide to upgrade the blower you will be the guy I contact for the kit![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I do however have a Procharger P600B sitting on a shelf that was originally for the stang, but I've been thinking about throwing it on the Jag in line with the stock blower......but it's not self contained and I'd have to tap into the oil lines.
