sourcing expansion tank hose in Uk or Ireland
I just snapped my expansion tank hose which runs from the thermostat housing to the expansion tank. (? Also known as the bleed hose / pipe ?) Part number W0133-1629070-OES and shown on attached link:
http://www.jtote.com/product_info.php/oes-genuine-expansion-tank-hose-for-select-jaguar-vanden-plasxj8-models-p-118157?currency=GBP&osCsid=432okdu49nfgh7odm4v1o7g f12
I’m in Ireland but usually end up shipping form UK. The pipe is only $15 in USA but I am looking at £40 plus on UK web-sites. e.g. a hose set from Britishpart.co.uk
http://www.britishparts.co.uk/.sc/ms/bdd/ee/4881/EXPANSION%20TANK%20HOSE%20KIT
1. Does anyone know where I can buy this expansion tank pipe for less than £30 in UK or Ireland. ?
2. Would I be totally mad to patch over break with flexible fuel line and jubilee clips ? (The snap is at the elbow)
Thanks Graham
Thanks Graham
Which elbow? The one at the rubber hose end? If so, cutting it cleanly beyond the snap and using a longer hose would seem to be a reasonable solution because it is really just making that portion longer. If the bend needs to be sharp in that region, just use two pieces of hose and a right angle hose mender.
Thanks ! I thought so but always best to check !.
Does anyone have a reasoanable priced Uk or Ireland source as I'll still replace for cosmetics.
I have some parts but am unsure if that exact item is in my stores. However, I think if you replaced it with a rubber section it wouldn't be a problem as it was someone's poor decision to use plastic parts. It wouldn't affect the way any of the cooling system worked if you used a rubber section.
S.
S.
Graham (09-19-2011)
clubairth1
29
05-10-2024 12:57 PM
abonano
25
09-25-2015 10:43 AM
