speed control
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
Hi Guys, can anyone tell me where I can obtain a diagram or a detailed fact sheet on "where the vacuum pipes on the xj8 cruise (speed )control go, I dismantled some and replaced those but half was done by someone else so now I am stuck half way.
Any light shone on this would be fantastic.
Received 13,090 Likes
http://www.jaguarclassicparts.com/uk...trol-equipment
And here's a similar diagram from the Jaguar Electronic Parts Catalog (EPC), which you can download and install from this forum. The only difference I noted is that the diagram at jaguarclassicparts.com includes a "+" vacuum hose connector, Part 20.
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/404x522/x308_cruise_control_500d7fc073c532d69ad9105991729908f9952a1d.jpg)
Cheers,
Don
andrew lowe (04-20-2015)
it was a broken + connector on the vacuum lines, hence the bodge with the red dice.
lol, I think and pray its my switch on the brake pedal, as that is the only thing that is original on my present XJ8, everything else cam off my working old XJ8, so a job for the week-end. all pipes etc. seem fine and clean so here is to luck!
And thanks again to all who contributed to my post
I want to add something, I found my Vacuum leak to the RF of the Engine Compartment .Follow the Vac from the Motor all the way from the Intake to the storage tanks to the RF then back to the Solenoids. I had all the Vacuum I thought was needed at those things but not enough to hold as Cruise above 20 mph? I started following the hoses and found 1 disconnected. A very small one yet enough to have cause me to buy the Brake Switch and agitate me for months.
Johnken
09-15-2015 05:46 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
