Speed sensor wont come out
So i was trying to remove the front passenger side sensor when the bolt desided to snap in half. However the other half of the bolt is no longer holding the sensor but still the sensor would not come out from the small hole. I sprayed wd40 and tried to pry it out with a flat heard but it stock in there pretty good. Any ideas how i could get it out w/out braking it? Thank you all in advance.
Hi newuser
Have you tried tapping the sides of the sensor (using a small block of wood and soft taps to the wood from a carpenter hammer)?
Maybe the tapping will cause enough vibrations to dislodge it.
Here is a photo from the wheel sensor just after it was removed. Photo is from the wheel sensor cleaning thread:
![Name: WSS-7.jpg
Size: 118.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/164595d1501273142-speed-sensor-wont-come-out-wss-7.jpg)
https://www.jaguarforums.com/forum/x...e7/#post208422
See post#1
Jim Lombardi
![Name: WSS-7.jpg
See post#1
Jim Lombardi
Thanks Jim, i will try the tapping next time. I don't think the piece that goes inside the hole is round so twisting it maight not be an option. If i remember correctly by looking at one of the others its kind of square-ish.
Johnken
09-15-2015 05:46 PM
innzane
09-02-2015 10:08 AM
