Sports Mode
Sports Mode
Hello all.
Long story short, just bought my Jag a few days ago. Me and my wife needed a 3rd car, because my 2-seater wasn't really a family car. saw this jag, they are very roomy. Bought it for $3600. Instantly fell in love, the car is a Vanden Plas, and looks beautiful, and is perfectly functional in every way. 140,000 miles, and mechanically perfect.
I am going to see my Father-in-law (I actually love my in-laws) and he is very, very excited about my purchase being a former racer and current car enthusiast.
The only problem is, I don't think my Sports Mode works! I have just found out today, the button does not light up when pressed, and doesn't feel any different (I would think that shifting would be closer to red-line)
Is it a fuse? electrical problem? or is the LED just not working, and there isn't much difference between Sports Mode and Normal Mode?
I am watching this thread, and will react to any feedback very quickly.
Thank you all for looking!
easiest way I would think to confirm operation of sport mode would be to fire the car up, turn the stereo and air conditioning off so there is absolutely no noise, roll your windows down, and then put the car in drive. When you hit sport mode while stopped the car should downshift into 1st gear whereas in normal mode you accelerate from stops in 2nd gear. If you can hear this downshift then your sport mode is probably working, if you do not hear the downshift you might have a problem.
good luck
good luck
FYI, the sport mode is engaged when the button is OUT (and the LED turns on when out)... same as the Cruise control button next to it - OUT is on (and the LED should be on on the cruise button too).
WHen in Drive and standing still - in normal you start out in 2nd, in Sport, you will start out in first - so the implication is, when standing still, switching from normal to S you might be able to hear the tranny shift from 2 to 1.
Ill be back tomorrow to give a final answer.
The "S" button is definitely changing shifting patterns.
To clarify so that I can resolve this issue, about what RPM should Sports mode be shifting at if in D from 0? Should it be damned near redline, or 6k? This will help me resolve the issue.
I dispute the info that the car does not begin in first gear for either mode. A very lively (nasty!) discussion was on this forum concerning it. I checked with my Enginuity software and indeed the valve engagement indicated either mode used the 1st gear solenoid sequence, with sport holding it there longer. If the car does not hold gear until near redline for WOT, you either are not in sport OR your throttle cable is misadjusted and slightly slack. Check the archives here and on the XK forum for slack throttle cable.
Would there be a fuse that this would route to? Also, about fuses, where would I find a fuse diagram? I only have the owners manual physically.
This paragraph is from the
bob gauff
AJ-V8 Engine
and
5HP24 Transmission
Introductionand
5HP24 Transmission
Sport Mode
When sport mode is selected by the driver using
the mode switch, the sport pattern is only
activated when a set cornering force is achieved,
or the kickdown switch is pressed. The vehicle
speed and the difference in speeds between the
two front wheels is used to calculate the amount
of cornering force.the mode switch, the sport pattern is only
bob gauff
most definitely. Probably 85% or so. Ill fix that tomorrow, but it is definitely not the primary issue. From what I hear there is quite a difference in getting rid of that slack, but to be careful because you might do it too much so that the throttle affects idle.
When I do find the solution, I will add it in the topic for documentation purposes.
Sorry, I was just repeating what I had read here recently without verifying through additional sources - yet I yell at the news media when they do the same... mea culpa.
Does the sport mode act differently in S/C models? This is what mine does: if I am pressing lightly on the brake, just enough to keep the car from rolling, I press the S button and can sense the car downshifting and the added torque makes the car roll forward. Also when cruising through the neighborhood with lots of stopsigns, I know that the car consistently starts off from complete stops in second gear with Sport off. When activating Sport in the same environment, it starts in first. Is this being disputed?
Marka
22
09-11-2016 12:09 AM
