Spring Compressor
Spring Compressor
Hey Folks, Have had the dreaded cluck from the rearfor a month now. Pulled the left rear strut today using the AutoZone loner spring compressor all the bushings were shot so new shocks are going in, but there is no way the new stuff is going back in with the loaner spring compressor. Anyone have success with a paticular compressor or do I really need to drop the A frame to get more drop of the control arm?
Thanks!
Thanks!
Thanks!
Thanks!
Hi
Here is great DIY writeup by (blackonyx.com) and probably the best photos of each step for replacing rear shock absorbers (during the reinstall it says "Support the control arm with a floor jack. Begin to compress the spring", sounds like he is using the floor jack (under the lower control arm) to compass the spring enough to get the lower shock bolt back in). See page 36 in the PDF file:
jaguar.XJ (X308) blackonyx net tech rear shocks.pdf
Jim Lombardi
Jim Lombardi
JPM50 (08-05-2012)
SD96XJ6L
11-05-2015 10:47 AM
