stability control fail
had the same problem on my 2002 VDP and it can be a very expenisive or free mix. Hopefully you don't have to replace the ABS module. I actually had a ball joint and bushing replaced and while doing it they cleaned the sensors and 3k miles later the warnings have not come back. Hopefully its the same for you.
as the other posts advise, check and clean the sensors first. i had the same problem. abs and stability control warning pops up now and then. after about 3 months it stayed on. i bought an abs module from ebay for 150. installed and bled the brakes - 1 hour job. problem fixed. called a couple of shops. they wanted anywhere from 1500 to 2400.
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
