Stability Control Fail Message
Old 04-18-2008, 10:44 AM
ballardrd's Avatar
Default RE: Stability Control Fail Message
FactoryJaguarTech -
I'm located in Tucson, Arizona. Royal Jaguar is our local dealership, and the next closest Jag dealership is in Scottsdale.Can the module actuallybe repaired?Royal Jaguar Service Reps have neveroffered usthis option.
Old 04-20-2008, 10:25 PM
Chimeing in my 2 cents... Autoenginuity supposedly sells a good jag code reader around $250 + updates. They are in Meza, AZ. They might let you test one out before you buy one. Dunno? Worth a drive before giving up.
Good luck,
Marv
(I get stability control failure every time I spin out in loose gravel.... my mech says comp just letting you know car lost traction. But then again, my amber light just blinks for a sec then goes out.)
Old 04-21-2008, 04:49 AM
Ballards problem is different 97. Good idea about the code reader.
The power pins come loose inside the module. They can be soldered back down. I personally have never done it, but a couple of the other techs have, with success. I am about to do mine in the near future for the same reason you are having problems. I will document as I go along.
Old 04-21-2008, 06:41 PM
they never offered it because it is considered tampering with brakes... i have done it many times.. but call it on the work order something different just to protect my self.. repaired module ground.. lol
it is easy to do and takes about 10 minutes to do .. just risky opening it without damaging them.. some company's do offer to rebuild them they charge about 200-400 ..
Old 09-15-2010, 07:03 AM
rotor jockey's Avatar
i have a 98 xjsport which occasionally throws this up, normally when started and in park but on shifting to drive it dissapears, i put it down to computer overload!
Old 11-21-2012, 10:09 PM
misham64's Avatar
I have 99 XJ8 same problem lights.
Fixed most of the Jaguar svc issues. Pulled the 4 liter and dropped in LS1 Small Block Chevy.
Looks like it was factory installed and parts are cheap.
25mpg hwy 21 around town.
Andrew at Jaguar Specialties was a wealth of knowledge for the swap.
Some hate it some love it.
Appreciate all you techs do to help us rookies with the Jag quirks.
Mark Isham
Destin FL
  #28
Old 06-20-2013, 09:20 PM
Blue Jag G's Avatar
I went by my dealership today, They want $115.75 just to read my codes!
Old 06-20-2013, 09:22 PM
Blue Jag G's Avatar
Originally Posted by ballardrd
FactoryJaguarTech -
I'll see if our Jag Dealership will give up those codes without charging us a King's ransom. Can't promise anything because as you all know, everything in America comes with a price! Sorry. I'll see what can be done on those codes next week and get back to you then. Thanks -
Ron
I went by my local dealership, they want $115.75 just to read the codes!!!!
  #30
Old 06-20-2013, 09:25 PM
Blue Jag G's Avatar
Sorry for the double post, silly lag on my internet..
  #31
Old 11-06-2013, 01:16 PM
oldjaglover's Avatar
Mark Isham
Destin FL
That's interesting. Do they get rid of the ZF, too? Does it now sound more like a Corvette than a Jag?
abonano
25
09-25-2015 10:43 AM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
Havigdort
09-13-2015 04:42 AM
jaguarbill
09-05-2015 11:43 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: Stability Control Fail Message
