Starting issues
Starting issues
Hi all.
i tried starting the car earlier on and it refused to turn over. when i turn the key i hear a clicking noise from the engine and a faint whining noise, The lights and dash are all lighting up ok so im wondering if its maybe just a weak battery needing charged.
Any help would be great
cheers
cheers
Kennymo (03-20-2017)
After checking battery charge and everything else, try waiting a few seconds between turning from ON to START (so, turn key to ON, wait for system check to end, then crank). I've had the click, whine, no turn over, no errors happen a couple times when I got overeager and turned the key immediately to start (like is done with most other cars...) but waiting a second or two seems to fix that.
