Starting issues
Ok so I checked the cable and everything seems good there. I also checked the ground cable at the rear of the passenger front tire. It was good too. I replaced the starter thinking it's just a solenoid going bad. It's just 2 bolts but the top one is the worst. I removed the air tube to the alternator and the oil filter (changed oil while I'm already under the car). This allowed me to put a 13mm socket on an extension and get to that bolt. Haven't had an issue yet. I hope that does the trick.
