Starting Problems!
Hi guys, I have a 2001 jaguar xjr and have had a massive headache starting the car. It seems to only start if I turn the key all the way and then go under the car and bridge the starter with a piece of metal. After that car runs fine but wont start back up if I turn it off.
I have checked and switched relays, fuses, exciter ring, ground strap and cleaned the connections. The gear selector does move freely when the key is on.
Help mate's!
Help mate's!
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1280x720/fb_img_1534253539869_2294424549ea23286c452e87f671d59a8618063b.jpg)
Your starter circuit is on page 53 for a SC engine
http://www.jagrepair.com/images/Auto.../jagxj2001.pdf![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
The duel linear switch is your transmission in park switch
The ignition switch is the same as on the earlier X300 version of your car
The last key rotation detent is the starter enable and is pin 1 to 5 closing as you have the connector removed in pic
No need to remove the round orange switch from the mechanical key barrel
On a meter this will be a wavery signal as a closed ( 0 ohms ) when rotated because it is spring loaded to open the circuit
On the other side of the connector on the car direction half the pin 5 is a car frame ground and should be close to 0 ohms
This connector can get corroded because of liquid intrusion like on mine
Editing
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x652/jaguar_key_switch_s_l400_1__0cacbf8eac13697eeda89f56cebb0689a871471e.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1125x737/x300_starter_switch_pins_untitled_1fee9e10b52faa1b8cf479456f49eb1b01243999.png)
Editing
I am assuming you swapped the specific starter relay ?
notice in the pic 2 groups of relays the same and dependent on the steering gear being in the way
On a different note the gear shift interlock solenoid on page 67 may be effected by the controlling BPM with a bad battery connection
You mentioned the gear selector does not freely move
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1710x1064/jaguar_fuel_pump_relay_location_pyazzua_bf1ba5950b9b7d296f10cdcc2c4d723eb0b7d601.jpg)
The following 2 users liked this post by ncanales33:
Jhartz (08-04-2019),
Lady Penelope (08-03-2019)
Before you start tearing things apart, try another ignition key. I've started to notice that the key I regularly use, sometimes doesn't start the car right away, I have 3 keys, not including the valet, 1 doesn't work at all, 1 works intermittently and the other works just fine.....worth a try.
oops I didn't see that you fixed the problem, nice looking car.
Clive
Clive
New skins next to the foam and not just covers are available at a decent price
The skins from someones review is not as suptal or soft as the original
There is a interior color code on the door sticker
https://www.lseat.com/products/1998-...ers-front.html![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
They will send you a sample swatch to see color match and I assume its not the best leather as they would use the better shop material for production of the actual
Just guessing
They take some time to condition with some lotion and stretch out to form better
https://www.jaguarforums.com/forum/x...olster-201906/
Just guessing
