Starts but wont stay running after new fuel pumps
Ok, I don't know where to go from here to diagnose this issue. I will try to keep it brief...
I was having occasional starting issues. No codes. Decided to replace the fuel filter. That seemed to help for a while.
Friday the car started but was running rough, wouldn't do anything more than idol. After a few restarts it would not start at all. Had it towed home.
I finished replacing both pumps last night. The car starts right away every time, but sputters to a stop after a few seconds. I had a friend crank the while I held the fuel test valve open. Fuel poured out. So I think the pump install was a success. Still no codes.
Any ideas?
Any ideas?
Is there a flu going around on our cars? This is like the 6th post like this in a couple weeks... I hope mine doesn't get it...
Seriously though-
1. Battery age?
2. Tensioners?
3. Fuel pressure at the rails is what?
4. Have you disconnected the battery and touched the leads to reset?
That should get things started, diagnosis-wise.
Seriously though-
1. Battery age?
2. Tensioners?
BrentGardner
28
04-26-2024 03:08 AM
msdg137
09-16-2015 06:24 AM
