steering column issues
So, the new 02 XJ Sport is great so far, but...
Steering wheel does not move up, down, in, or out with steering column control knob, horn does not work, steering wheel radio controls do not work, turn signal makes no sound when activated. Haven't tested the cruise control yet. I'm thinking there is something amiss with the wiring in the steering column??? Any suggestions on what to look for?
Paul
Paul
Here is a copy of the wiring diagram that may assist you in your examination. Obviously you want to check connectors directly under the column and "A" pillar, and when testing for voltages, use a DVOM. I will say this upon examination of the ground of all of those circuits, (and the only one common denominator to all of those circuits specifically) and that is they all terminate at the same ground point. FC17R which is the EMS bulkhead ground stud on the center right side of the vehicle under the dash area. It's location can be found in the diagram provided.
The PDF is too large to upload, so I will place it on a website to obtain, but will not be there forever...save a copy locally
http://ocu-stars.okcu.edu/dbox/jfj2002en.pdf
Paul, let us know what happens after examining the FC17 ground.
SS, when I first starting looking at the circuits, many of them do pass through the BCM to operate, however, the cruise and radio controls do not. Seeing that those also are dead, it would lead me to back to the common denominator, and that's the right side tab of the FC17 ground stud. If it were mine, I would provide a temporary ground wire, back probed into SW1-5 or SW2-5 (black wire/pink stripe) (SW2 6-WAY JST / BLACK - CENTER OF STEERING WHEEL) and press the horn to see if the horn blew. If it did I would bet good money that either FC17 was loose, or the right side tab was damaged, wire cut, or the FCS28 splice had failed inside the harness.
After spending a few minutes looking under the dash and realizing that I would have to dismantle a lot to get to the wiring, I took the car to our friendly neighborhood Jaguar garage. The wiring problem was an easy enough fix for them, although it would not have been for me. The broken wire was under the airbag which was removed to fix the problem. That's as much detail as I got when I picked the car up. I also had trashed front brake pads and rotors due to poor brake maintenance from the previous owner. Fortunately there were no other major issues. The owner of the garage told me that no XJ's prior to 2004 had the metal tensioners installed in the engine from the factory, and that I would need to have the valve covers pulled to check the condition of mine soon, since I have just over 100k miles on the car. I have read numerous posts saying that any car with post August 01 build date has the metal tensioners, so I'm a bit confused about that. Anyone care to enlighten me? The total bill for new brake pads, rotors and a fully functioning steering column was under $800, so I felt like I didn't do too badly on the purchase price of the car. Even the garage owner was surprised at what I paid for the car. Now if I can just get my 07 XKR back front the dealer I'll be really happy. It should be ready to pick up today or tomorrow.
rusty37
04-05-2020 07:40 PM
