Steering Column Reach Motor
Guest
Posts: n/a
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hi
Does anyone have any experience of replacing (or even repairing) the reach motor on a 2001 (X308) XJ8? Mine started clicking, so the motor's still turning but obviously the gears are not engaging (and the steering wheel's stuck in the farthest away position).
I've lots of experience working on cars, but not done this before, so was wondering if its something I can do in an afternoon.
Also - does anyone know if the earlier models' reach motors fit the X308? The dealer wants £250 for one so it looks like I'll be searching the breakers yards.
Many Thanks
Mikey
Many Thanks
Mikey
Hi Mikey,
I took a look at my JTIS and the reach motor assembly appears to be on top of the column about where the tilt motor on the left side would be. I'm guessing you would have to tilt the steering column all the way down in order to reach it. It looks like that if you can get to it you should be able to replace it but looks tricky. I had the reach motor on my '96 XJ6 go south and I just adapted to it in the forward position. You can try imitating Stirling Moss.
Good luck,
Mike
Good luck,
Mike
RaceDiagnostics
09-13-2015 02:22 AM
jagent
09-12-2015 09:10 AM
1964Daimler
09-09-2015 11:28 AM
