Steering Column won’t fit back in
I have a 2000 xj8 VDP. I had to remove to steering column and now it won’t fit back in the shaft. Help I’ve tried wedging the clamp with a pry bar and flathead screwdriver….I didn’t want to chance gapping it too far..Please help, are there any tips or tricks to refitting the steering wheel column. Please help!
https://www.jaguarforums.com/forum/x...r-time-223146/
There’s some helpful advice about those upper column clips in that post. Post #5 to be exact.
I used either an air hammer with a chisel bit that would spread the coupler apart or a chisel and hammer. You might want to blow the splines off on the male and female end to make sure there’s no debris and also use some antiseize to also help with the install. You definitely want to use some kind of chisel to spread the coupler though.
When I replaced my car steering column lower section there was nothing special at the upper clamp area. Regular shape axle and regular clamp. Old one came out pretty easily and new one went in like it was greased. Of course clamp has to be exactly in correct orientation otherwise it will stick. Bolt needs to be installed after lower section is pushed all the way to the upper.
No Quarter
25
02-24-2022 10:07 AM
lovelylellops
05-17-2013 06:09 AM
