Steering high pressure line melt down
Need help ! 2002 VDP 4.0 liter high pressure side steering line leak . Disconnected the battery (neg) side . Took line off car and had it repaired at a fluid line repair shop . They said they fix them all the time . Put the repaired (metal/rubber) high pressure line back on . Simple job . Filled the fluid back up . While connecting the neg battery post back up , 15 seconds to tighten . Looked over the boot and smoke and flames billowing from engine compartment . Disconnected neg battery in 15 seconds and put out fire ! This metal/rubber line created a dead short to the steering system . Looks as if the steering system is in all rubber mounts . ANYONE ever have this nightmare ? Need help on some burnt wires going to the ac compressor . Changed the line back to rubber to trouble shoot the problem . There was no problems with the test rubber line at idle . I have bought the original line for the jag . Need to get the wire issues straightened out before reinstalling the line .
You'll want to bookmark this site by a site member who's collected tons of knowledge on Jags... JagRepair.com - Jaguar Repair Information Resource
These are two electrical schematic pdf from that site you'll want to review... http://www.jagrepair.com/images/AutoRepairPhotos/jagxj2000.pdf ...and.. http://www.jagrepair.com/images/Auto.../jagxj1998.pdf
Let us know if you need more info and be sure to clean off your connections from the steering fluid.
voojugri (07-11-2019)
qwiketz
17
01-18-2012 01:09 PM
