Steering improvment XJ-XJR?
Hello! Have had many thoughts regarding what is in my mind missing to transform this sleeper, to not just a beuitifull dragster/chesterfield sofa, but to a sharp tool for also cornering. My car is a XJR with CATS.
(Basicly, I think the biggest issue is that my last car was a Alfa 156 with SP3 package. Very frim indeed, but also quite ok on motorway.)
I have read as much as I can find and as far as I understand this is what is normally done:
-New bushes or power flex equiv on fwd lower/upper arms+roller bars
Please! Any input on this from somebody who has tested this! Is the differnece really noticable between fresh org rubber and polyuretan ones?
-I think on my particular car that steering is much to less informative. It's more or less dead.
Is this how they felt when new? Input from experinced viewers
-Tried mounting solid subframe mounts, getting rid of the cracking rubber thingys (yes mine are as well
-And least but not last, have anybody tried to reduce the extreme large ratio between steering and reaction, hence change steering rack as whole or just internals to reduce number of rev for lock to lock. Maybe by going for a straight ratio rack instead of present dynamic with high ratio in centre an low towards ends.
I hope this can open up to some really serious intressting discussions. I plan to get in contact with ZF to see if they could dig out an internal rack that would fit the housing and pinon of org steering rack, maybe somebody else has allread done this....
Cheers!
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Cheers!
Any other experince from upgradig handling???
There won't be a fault code if you disconnect the power steering connector on the rack...you can see it on the left side of the car looking down the side of the engine to the rack...ive been meaning to do it as I've heard it improves steering response quite a bit...on aside note I've replaced all my bushings front and rear and that made a big difference on cornering...I don't have CATS and am pretty happy with it
My car originally had the steering mod fitted from Paramount, developed for the XKR....since the re-build I haven't replaced it, but I've fitted a switch ready for it.
The remote wiring is connected up to the steering relay, so it can be turned on and off in the cabin.
I used to use it a lot, usually on my way home from work, I'd pop it in sport and deactivate the assisted steering (which is way too light compared to the BMW's I use for day to day driving).
It gives more weight, and feels much better at higher speeds, a man's steering.
Racing green sell the kit now for around £50, Paramount charged £250 to fit it I understand.
This is the only steering tweak for our cars. You could solid mount the rack, by removing the rubber bushes and fit custom aluminium items. But I doubt you would feel any difference.
What exactly are you looking for in the steering? a quicker rack will cause issues, if you want it to handle like an M3 track car, you won't be able to achieve it.
I recommend the poly bush kit for the front.
First of all, Thanks for the feedback! Interesting stuff with the before and after change of bushings. It would be extremly frustrating to put in all that work changing bushing just to find out that it's still something missing....
What am I looking for, well, it does not need to be a M3 track day car, but I want it to handel to match that massive engine. It seems as I should plan to change bushings, I am tempted to try to fix mount the fwd subframe mounts, than use std rubber units due to price, or poly ones if wallet agrees in a couple of month. Defenetly try to disconnect the servotronic actuator, but also change steering colum, as this lower cv joint is with exessive play. But, as I will be needing to do this outdoor, it will need to wait until spring is here, as we have about 10deg below frezing point now...
Thank you all for the input!
/Per in Sweden
As far as wear is concerned, the low speed system is a "boost" beyond what is normal. So, the gears could face more pressure. However, that would be at the lowest speeds such as when parking. If you are always careful to be in motion while steering then the extra strain should be negligible. Steering the wheels while stopped is the worst thing you can do to a steering system.
car, connection, failure, fluid, function, jaguar, power, relay, servotonic, servotronic, steering, track, x308, xj8, xjr
