Steering rack leak
Noticed that my steering rack boot was filled with power steering fluid..
I bought a second hand dry rack at a Jaguar salvage over the phone i ,asked for a late 2002 rack .
Now i wonder are there any differences in the xj8/XJR steering racks i have a 2001/2002 XJR 100..?
i just received the rebuilt rack over eBay 200 dollars .will install this weekend
i wouldn't suggest to buy any used mechanical parts as learned as few lessons in the past on cars. you are paying the labor for installation, what if the used part didn't work because it has some age on it already.i only buy used body parts.
DJ-Roy (07-15-2014)
i wouldn't suggest to buy any used mechanical parts as learned as few lessons in the past on cars. you are paying the labor for installation, what if you didn't work because it has some age on it already.i only buy used body parts.
about 2 days before i get it back .
Its my daily for this summer ,so i must get it on the road asap
The prices oversea are much higher ..
Got a link for that?
Thanks!
Chris
The 20" inch wheels dont rub the wheel wells when full lock left and right ,and the cat drives straight with minimal pull to the left ,i have that aligned only problem the steering wheel is 25% turned to the right.
I try to find the procedure getting the bolts lose behind the steering wheel ,you have to turn the wheel to get to them ..and the battery disconected..
XJ8 HALF WOOD WHEEL CHANGE Photo Gallery by Max Heazlewood at pbase.com
I would also suggest yo get hold of a bottle of LUCAS
Power Steering rejuvenating fluid...this stuff is excellent
and will help prolong the service life of the rack.
Suck out the old oil....warm the Lucas bottle in hot water
and pour into p/s resovoir and top up with Dexron111.
DJ-Roy (07-17-2014)
Just did the job ,thank you you for the helpfull advice Xjay8 .
Easy to do ,important not forget anything.
Do the fluid treatment but later when i get that stuff.
The steering wheel sits perfect now ,alignment tommorow.
nice to know how its done because i have a spare SVO R steering wheel covered with sumthin new ,to swap soon .
easy when you know how.
If you just dive into it, there are a couple of subtle little traps
for the uninitiated ;o]
DJ-Roy (07-19-2014)
rusty37
04-05-2020 07:40 PM
Richard_gib
09-12-2015 07:08 PM
