Steering wheel wondering after front brake job
So I replaced my front brakes and rotors and while I was at it I decided to lubricate some of those suspension/control arm bushings with WD40 . Now when I drive in a straight line the wheel suddenly pulls to either side then it's fine after a moment. Would spraying oil to some of those front suspension/ steering arm bushings cause this to happen? I did make sure the front wheels where spinning freely while I had it on the jack and the only thing I noticed was a very slight dragging sound(as if the rotor was touching the caliper bracket) but it was very fainted.
Received 3,887 Likes
Newuser, check your tie rod ends. To me it sounds like you have one this is loose and what you are experiencing is the wheels will be straight as you are driving, but when you turn the wheel, one wheel turns as the other remains straight, leading to the wheels fighting each other. Then once the one wheel catches up, it will drive straight. After that, not sure what it could be.
Before I did the brakes I noticed that only 1 of the 4 front brake pad was down to the metal (the one on the piston) and that is the side to which the car pulls. I wonder if the caliper is malfunctioning. Although I have put the car in neutral and let it roll at very low speed to see if it stops abruptly and it does not.
tonimccloud
19
01-18-2020 01:56 PM
Doberman_Fan
22
12-24-2019 06:21 AM
