Steps/Advice for Head Removal?
2001 XJ8 - 77K miles, picked up cheap knowing it needed work. Started with multiple misfires codes here's what's been done so far.
NEW
2 new upsteam O2 sensors
8 new plugs
fuel pump
fuel filter
air filter
timing chains, guides and tensioners (all)
water pump
belts and hoses
fuel injectors cleaned
Got all my misfire codes down to a single cylinder #4, had car towed and a professional Jag tech do compression test and check all my work. Compression in all cylinders were within range 170-190 except (you guessed it) no compression in cylinder 4. Sent a camera down the plug hole and picked up something (valve or spring). Car is now back home and I'm about to set out pulling the head off - (of course wishing I was smart and experienced enough to have done this when I did tensioners and chains. A few questions for the experts out there:
1.) any good step by step instructions on removing the head... I know many steps are the same as when I did the timing chains/tensioners.
2.) Hoping it's no more than a broken valve and a machine shop can rebuild - what else do I need to be checking for with regard to piston and ring damage once the head is off.
thanks
jamie
NEW
8 new plugs
fuel pump
fuel filter
air filter
water pump
belts and hoses
thanks
jamie
Pull the head and you will know everything you need to know. My guess is:
If there is something loose in the combustion chamber, it could be a bad day, hopefully it is just a bent valve. If it is a dropped seat, you may be looking at a replacement engine for various reasons.
Keep us posted as to what you find in there.
DriverEght (04-07-2014)
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-11-2015 10:04 PM
1964Daimler
09-09-2015 11:28 AM
