Stereo Upgrade Add Subs, Amp, Line out Converter
So I've purchased 2 10INCH Sub boxes, 1 amp, 1 amp kit, 1 line out output converter, my guy that was gonna do install has been tied up for last 2 weeks so I'm gonna try to do this project myself. I was told I could tap into the rear speaker on the rear door.
1999 Van De Plas, X308
I dont know really anything about stereo systems, electronics, etc
You need to provide us with more information, whether yours is a standard or premium system.
Next, if you've never played with this stuff, you'll need to do a lot of site searching and reading. There are tons of posts on this.
Here are a couple screenshots and I'm including the pdf they came from to assist which links at the bottom.
Okay thank you for the diagrams, unfortunately I've never been able to determine which system I have as there are no Alpine nor HK labels on the speakers grills nor the head unit. I've pulled the unit out to cess the speaker wires the harness came unplugged which helps me get a better look at the colors, in my mind this where the line output converter will splice into?
Look in the rear window deck, if you have a speaker back there, you have the premium. Also, look in the trunk, if you have the premium, you'll have a cd changer and nav unit.
+1 to KC and a fascia you may need and my setup presently.... https://www.jaguarforums.com/forum/x...-piece-165345/
Here's a thread by LaserSVT, he does stereo installations and its obvious by the work in his car (he may have deleted some pics, they didn't all load when I opened the link)... https://www.jaguarforums.com/forum/x...ag-xjr-216855/
so under the rear passenger seat is a fuse box and several bundles of wires some connecting to harnesses, just a thought could I connect my Loc to here? Just knowing that my ability to run it to the boot is limited I'm trying to get as close as possible to the boot. I have the standard system so no factory amp nor sub to run off. Oh how I wish there were!
I avoid social media and not that I don't wish to help, but discovery is your best teacher. Pay attention to that first diagram I posted, its all you should really need to figure this out. You have to do some searches as well. I have other posts (and there's many others who do about other stereo issues) where I showed a guy how and where to run new wire to the trunk and bypassing the antenna mast (which I despised). Using the premium diagram and a multimeter, I did this... https://www.jaguarforums.com/forum/x...ve-one-103359/ ...as well as the wiring in that other link I posted on the fascia.
None of this is a quick patch thing. You have to keep in mind, your dealing with 20 yr old technology, in a then, premium car, with a stereo specifically designed for it. Which is why KC and myself (and many others) went 3rd party to get our results we wanted. Ironically we chose the same speaker combo...good people, good taste I guess...LOL.
Just a heads up, thanks to all your help, I was able to successfully install my own subs and amplifier with line output converter and It sounds amazing! Thank you all, I'm so happy I was able to do it all myself, besides the remote wire which was tapped into my antenna.
Thanks so much Jag Forums!
The following 2 users liked this post by dakico968:
Coventrywood (09-23-2020),
Highhorse (09-25-2020)
campaign308
39
08-26-2014 10:10 PM
