Still smoking,oil burn after valve cover gasket replacement.
The most likely problem is a crack around the bolt hole on the cam cover that opens up when tightened down. Another possibility is the part load breather is plugged at the cam cover orifice and will build pressure on the left bank cam cover. Try pulling the part load breather hose and running a drill bit held by a pair of pliers to clean out the carbon buildup.
David Bedoya
01-15-2017 04:12 PM
harryjbrice
Diesel variants - All models
01-10-2014 07:43 AM
unionjack
01-14-2011 09:21 PM
