Stop lights & key fob not working
Good morning folks.
I've just acquired a rather fetching Roman Bronze 2000 X308 which was on it's way to being scraped. I've been going through it and it seems in not too bad shape at all, mostly electrical issues so I'm keen to try and save it and enjoy it. Looking for some help with the stop lights and key fob.
Stop lights.
Really not sure how to further diagnose the issue, I'm a complete electrical newb and would really appreciate any help.
Thank you,
Andrew.
Is it correct to only have 2 connection blocks on the SLCM?
This wasn't connected? Normal? Seems like a lot of harness that isn't going anywhere!!
Stop lights.
- Left & right stop lights not working
- Warning on dash message display
- Bulbs look fine
- Brake peddle switch is ok
- High level brake light is ok
- All other lights in clusters are ok
- Was working but stopped after reconnecting the SLCM.
Thank you,
Andrew.
Click on twice to magnify , right click to drag around
Does the SLCM have the correct software # , the master software tag is under the forward bonnet as a label near the windshield
SLCM part # ?
The SLCM may need a "hard reset "which you can do ypurself but there are cautions on your stereo head lock out for a non - USA model
A hard reset is more that removing the positive battery cable for a moment
SLCM part # ?
LockNumber25 (01-27-2022)
Left
Blue (stop light) 4.3v
Red (tail light) 11v
Right
Orange/Yellow (stop light) 0.0v
Green (tail light) 11v
Looks like someone has had a go at this before. There was a wire (removed by me now) running from left blue to right orange/yellow.
Left
Right
Right
Left
Right
Parker 7 (01-28-2022)
Checked the SLCM output and getting the same as at the lamp cluster connector
pin3 - right stop 0.0v
pin9 - left stop 4.4v
pin1 - input 12v from brake switch relay? - seems to be 0.0v too. My wire is O but diagram shows OG so not 100% this is the input.
See page 62 and 118 for the pin 1
Researching . looking for pin 1
Stop lamp relay # 5 socket # 1 ? , should be hot at all times
jagrepair.com/images/AutoRepairPhotos/jagxj2000.pdf
LockNumber25 (01-28-2022)
