Strange beeping..revisited
Old 05-30-2017, 09:21 PM
3timejag's Avatar
Default Strange beeping..revisited
I'm going to throw this out there again, I thought I could live with it, but ITS DRIVING ME CRAZY!
When I start my 98 XJ8, or even turn the ignition to the on position...
I get 5 beeps, five consecutive times with a short pause in between each series of 5 beeps. Total of 25 beeps.
Sounds like it's coming from the drivers side of the dash.
This occurs AGAIN after driving for about 30 miles.
Then it seems random.
But it's doing this every time I start the car, or turn the ignition to the on position.
Does anyone have any ideas as to what this could be?
The car seems fine.
Old 05-30-2017, 10:04 PM
nilanium's Avatar
have you checked the codes stored in the climate control module? https://www.jaguarforums.com/forum/x...nfo-faq-66454/
3timejag (05-30-2017)
Old 05-30-2017, 10:30 PM
3timejag's Avatar
I checked them about a year ago and cleared them. Looked again several months ago and there were no codes, so yes, to answer your question, but I'm nor sure where to go from here.
I will check to see if there are new codes.
Thank you for your help!
Old 05-31-2017, 01:29 AM
Einhead's Avatar
My brother had this on his -98 Daimler... least to say, he almost got insane too. From what i can remember, its a audio warning that reminds you that the warning light bulb for airbag has died.
Check the "98 XJ8 Technical Guide" at jagrepair.com
You have the full explanation at page 102.
To get rid of warning, replace faulty bulb, ie. intrument cluster out.
/E
The following 3 users liked this post by Einhead:
3timejag (05-31-2017), JagV8 (05-31-2017), nilanium (06-01-2017)
Old 05-31-2017, 06:05 AM
3timejag's Avatar
I will check that out for sure! Thank you very much.
Old 06-01-2017, 08:19 AM
3timejag's Avatar
Well, the warning light is not coming on when I first start the car, so it must be burned out like you said. Do you, or anyone following this, know of a way to disable the actual "beep"? I hate the prospect of repairing one bulb in an otherwise working cluster.
Old 06-01-2017, 08:37 AM
Einhead's Avatar
Carfully pull the wooden facia straight out.. it only sits in a few metal clips, remove cluster, if you dont have a lamp awaible.. swap the lamp out with something else... maybe the park brake warning light.. or hi/lo beam will fit..
Even though its annoying.. its a safety feature!
3timejag (06-01-2017)
Old 06-01-2017, 08:42 AM
3timejag's Avatar
That sounds good. Thanks man!
Old 06-01-2017, 01:53 PM
nilanium's Avatar
The wood panel comes out easily by pulling - I hook my fingers on the insides of the outer edges of the circles (so, furthest left and furthest right points) and just pull. You'll need to remove the two circular button modules (fog lights and trip buttons) they are just snapped in, then undo their harnesses, then 4 screws and 2 big harnesses will free the cluster. The cluster is one of the places in the car where the backlights actually use easily available bulbs.
Old 06-03-2017, 06:29 AM
3timejag's Avatar
Okay, last question....and I really do appreciate everyone's advise and input on this!!
Do you know if that particular bulb (airbag warning light) is soldered directly on to the circuit board, or is it a twist our, or pop out type situation?
Old 06-03-2017, 06:33 AM
Einhead's Avatar
Its an pop in pop out.. sort of... any well sorted gasstation should have it... ie. its not a Jaguar specific one
/E
3timejag (06-03-2017)
Old 06-03-2017, 06:41 AM
3timejag's Avatar
Great. I don't mind soldering, but didn't want to have to get all the way to the circuit board if possible. Thanks a million!
Old 06-04-2017, 11:56 AM
jcreaden's Avatar
I actually clipped the speaker wire in the steering column as a temp fix much quieter ride now but no ts signal tic toc either. I found the signal box to it in the wiring diagrams and plan to see which signal powers up when it beeps and trace it from there. its driven me crazy since I bought the car. such a relief to silence it finally. but be aware that you get no other audible warnings so just keep a close eye on things
3timejag (06-04-2017)
Old 06-04-2017, 11:59 AM
jcreaden's Avatar
also, did the bulb thing work for you or no just curious
Old 06-04-2017, 09:20 PM
3timejag's Avatar
Thanks to all, I am actually traveling right now with the car. Drive over 400 miles today and it did its beeping thing about every 30-45 min. so I've had just about enough!!
I didn't have time to address the bulb prior to my trip, so not sure about that approach just yet. I'm going to take a look when I return home later in the week.
As for disabling the beeping sound via cutting that wire, thank you for the suggestion. I had thought about trying to trace that down and disable it, before I just super glued a pair of earbuds in my ears. Lol, anyway, I may go that route if I can not solve the bulb issue.
Old 06-04-2017, 10:05 PM
jcreaden's Avatar
its simple really a phillips head screwdriver to the bottom of the steering column drop the cover theres a speaker right under the ignition switch I left enough room on both sides of the cut to solder back together when I figure it out. ten minutes really quiet ride. safe travels to ya and good luck
3timejag (06-05-2017)
Old 06-05-2017, 05:40 AM
3timejag's Avatar
Outstanding! I will do that asap and let you know when I get it done. I really appreciate that info man.
Old 06-05-2017, 08:24 AM
3timejag's Avatar
Alright! Problem solved, went to local Auto Zone ad borrowed a philips head and wire cutters.
Thanks dude.
Old 06-05-2017, 08:36 AM
jcreaden's Avatar
glad to help
Old 06-07-2017, 08:02 PM
Kugelspritzer's Avatar
I haven't experienced any beeping yet, but I have noticed a random high pitched sound that comes from somewhere. I first noticed it while cruising real slow through heavy downtown traffic. The radio volume was down low and suddenly I hear this high pitch Mmmm. sound. I thought it may have been because I had my hand on the gear selector so I removed my hand from it that didn't make it stop. It's done this several times for no apparent reason. Please help.
