Strangeness. Electric suddenly not working, then working RESOLVED...
So, I came back to my car after dropping by a store today and it didn't react to anything electric. ignition, cabin lights, trunk, etc... almost like it was a dead battery.
I had a buddy come with jumper cables, and the second I attached them to the under bonnet terminals, everything started working again.... like it just needed to be reminded that it had a charge... I didn't even leave the jumper cables on when i turned on the car.
Now I'm just confused... Any guidance or experience with this issue?
Are there gremlins in the wiring? lol
Received 9,010 Likes
The connections under the bonnet are known to have problems if they loosen and or become corroded. Check the power leads at the "false bulkhead connections" and at the fuse boxes, especially looking for any discoloration or other signs of corrosion, then tighten them, CAREFULLY so as not to break the small plastic insulator pieces.
JimC64 (05-22-2014)
Wait... we have terminals under the bonnet? Where are these?
My battery is practically inaccessible now, so this could be a huge help in the future
:edit: never mind, found this
https://www.jaguarforums.com/forum/x...solved-115858/
The following 2 users liked this post by grandell:
Catenaccio (06-04-2014),
sparkenzap (05-23-2014)
If the battery is in good condition and the leads are clean and tight, I think it could be due to the chip in the key head failing to pair with the Exciter Ring in the ignition switch. (this used to be a separate component on earlier models such as the XJ40 but looks to be part of the switch assembly on the X308)
This electronic 'handshake' unlocks the ignition sequence. If it fails, it's just like putting an unprogrammed key into the ignition - nothing happens!
Thanks guys, I've got a lot to start with here.
Battery terminals were pristine last I checked, but it never hurts to check and recheck again.
I've never checked the "false bulkhead connections", so that could be an adventure, but I'm putting my money on that needing some cleaning.
And last but not least, yes, I've had the issue with the key not wanting to do a proper handshake with the car. That issue only presents itself in freezing cold weather... which does make me suspicious of a general battery issue. It might just be time to replace the battery.
I'll hit all of these suggestions one by one as I have time this weekend and hopefully return with some answers.
Thanks!
Thanks!
Well, it hasn't happened again, yet... So that's good.
I went ahead and cleaned some rust off of the false bulkhead while I was out there today.
Note: when working with that nut, remember, it's hot... and when wrenches touch the body of the car, sparks fly. lol.
We'll see if the issue comes back... or until my next adventure... Thanks.
JimC64 (06-05-2014)
I had a similar problem. Car would not start, no click, nothing. Call the wife to bring the jumper cables, touch cables to battery terminals and power comes on. The negative strap was very hot. It turned out the crimp on the ground strap was not making good connection. The battery terminals were spotless. Replaced the ground strap, problem solved.
JimC64 (06-05-2014)
On the other hand, in a pinch, the false bulkhead stud is ideal for jump starting. It terminates the cable leading directly to the starter which then daisy chains to the alternator output. From stud to starter is maybe three feet of very heavy wire. It also feeds the battery through the high power fuse. Thus, all systems will be getting juice.
The layout of the power distribution circuits showing the above can be found in the electrical diagrams in the earlier pages under "main power distribution".
sparkenzap (06-05-2014)
Catenaccio (06-05-2014)
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Charlene n John
09-28-2015 06:01 AM
philwarner
09-05-2015 10:05 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
