Stuck in park
Old 08-14-2019, 06:25 PM
Highhorse's Avatar
Received 1,797 Likes on 1,319 Posts
Hey Bob, if he hasn't cleared the codes, ..will he still be receiving them then?
Next, have you cleared the codes AltonJag?
For your instrument pack, double check your connectors, as stated, if they're not properly seated, they won't work.
Old 08-14-2019, 08:20 PM
Received 8,138 Likes on 4,910 Posts
If the INSTPK has failed and compromised the CAN bus, then clearing the DTCs is irrelevant.(they will not clear if it is a HARD FAULT)
The INSTPK is the gateway to the networks.
bob
Highhorse (08-14-2019)
Old 08-15-2019, 08:42 AM
AltonJag's Avatar
I don't know the code clearing process
Old 08-15-2019, 09:08 AM
The DTC's are read and cleared using an OBDII 'scan-tool'.
Attempting to diagnose and repair without one is going to get very difficult and time consuming.
The best tool for looking at ALL the modules on the CAN bus is WDS, IDS or similar.
A generic 'scan-tool' will at least read the ECM.
bob
Old 11-07-2020, 11:50 AM
Bob Cutlip's Avatar
With so many lights, error messages it may be a weak battery or connections. My 'Locked in the park and no brake lights' were due to a broken wire at the brake switch connector. I probably did that by replacing the switch.
giandanielxk8
01-23-2018 05:35 PM
anthawk
01-28-2017 04:29 PM
doc
11-24-2014 05:47 AM
jaguar lover
US Central
05-12-2013 09:12 PM
The Craig's
17
01-13-2012 02:45 AM
Quick Reply: Stuck in park
