Stumbling?
Hey All,
I recently replaced my secondary tensioners, valve cover gaskets, spark plug gaskets, and spark plugs. I also repaired my abs module by soldering the joints. My problem is now the car (00' XJR) stumbles at high speed. When doing about 80 mph, I punched it and it started missing really badly, but doesn't do it at low speed.
Any ideas?
Oh yeah, I installed new NGK iridiums. The spec called for them to be gapped at .052", which I thought was a bit much.
Any ideas?
I just had my 99 XJ8 in the shop last week for scensor checks, and stability contol and traction control failure. When they got all that fixed, the performance limit was acting up.
They said that a Knock scensor was sending a false reading and skipped a valve all together. He cleaned the fuel filter, and injectors. He also changed a bad knock scensor. It doesn't have that problem anymore.
Start small. 93 octaine fuel, new fuel filter, diagnostics check on the knock scensor.
Just a couple of thoughts-
Are you absolutely sure you did the valve timing by the procedure? Are you sure you did not distort the flywheel sensor wheel by using the peg to hold the engine while torqueing the upper emd? Is the crank sensor in right? Other than than, I would look for loose plugs or hoses.
Are you getting any codes?
JaguarRookie (01-05-2019)
Hey All,
Any ideas?
Any ideas?
Thanks,
Dan
Have you checked for air leaks in the air duct from the air filter to throttle body? Cracks in the air duct?
What do the codes say now?
If you are getting an air leak you should be getting some codes. If no codes are present then your fuel pump might be starting to fail. Check your pressure at the fuel rail. When reading your post I thought of the fuel filter right away but you said it's been changed out and the problem got worse.
n2audio
17
10-09-2015 10:53 PM
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
