Stumped. Door lock actuator or relay
Hello guys my 2000 xj8 vanden plas driver side door lock is on the fritz. Somtimes it will work with the fob or with the inside unlock button. However there are days where it does not work and when it doesnt the unlock button inside doesnt unlock the other doors but the key fob does when taken out of the ignition. Its becoming a real pain especially when trying to unlock my doors for my passengers to get in.
I cant open my drivers side door from the inside either but I'm pretty sure its not related, just a bad door cable.
Thank you
Thank you
The short answer is that most likely a micro switch in the door mechanism isn't setting because of the bad door cable on the interior latch handle. The cable runs from the handle all of the way to the lock mechanism and up onto a pivot. When the cable frays and quits working it effects the latch position.
Assume you are not getting a warning that the door is open ? The mircro switch is a known fault path and Jaguar does not sell the switch as an individual part .... if it's seeing the door open it will not allow the locks to work.
When you use the key in the lock you are moving both the lock and the actuator ..... May try looking in the wire diagram and see if the micro has two pathways ... my friend was getting the dash warning w/ no locks working .. so it was easy to tell that the door micro was not working.
We did as you and got a working unit from a wreck.
Assume you are not getting a warning that the door is open ? The mircro switch is a know fault path and Jaguar does not sell the switch as an individual part .... if it's seeing the door open it will not allow the locks to work.
When you use the key in the lock you are moving both the lock and the actuator ..... May try looking in the wore diagram and see if the micro has two pathways ... my friend was getting the dash warning w/ no locks working .. so it was easy to tell that the door micro was not working.
Will do thank you for the response guys! I appreciate it especially since I cant afford to have a mechanic take a look at the problem.
Yeldogt, yes the warning light does come on when the door opens. I have done a reset on the vehicle and bought a new battery a few months ago.
However, the door will no longer open from the inside after switching out the cable, it was working fine after the new cable opening the door and unlocking it. Now all it does is unlock the drivers door but doesnt let me open it from the inside I have to roll the window down and open from the outside again.
I had similar problem as OP, replaced cable and still the system wouldn't unlock. Did your WD-40 trick, worked like a charm! Thanks!
Replacing latch
I had a similar micro switch issue on drivers’ door. It killed one battery and was working on another! I found a remanned unit online. Problem solved. Don’t recall the name of the supplier so check my posts. Really fast service. I think they were in the upper Midwest.
smtguy
04-14-2019 07:54 AM
