Stupid Restricted Performance light came on
Well, seems I got hit with the Restricted Performance light. Hooked up my Code reader and got a Very Small leak in the emissions, time to get the XJS out of the garage, and the VDP in and start tracing it out. Guess this is good opportunity to make a smoke detection can I have seen on Youtube
There is quite a wide range in emissions before the Engine light will come on (and I am not even sure it will result into a Restricted Performance).
Keep other causes in mind.
RJ237 (11-05-2016)
Doing a smoke test is always a good idea, but I do not immediately see how a small leak (as you described) can set the light.
