Sudden multiple sclerosis: P1601, alternator, fuel gauge, suspension, lumpy idle
Dear Jaguar Enthusiasts,
I need some advice to diagnose my 2003 XJR with 119000 miles, which I enjoyed for the past 11 years.
The fuel gauge has been intermittent and frequently shows empty with "Range Error". However, I recently discovered that when restarting the engine the fuel gauge comes back to normal after a delay of ~20 s
A day after the most recent recent diagnostic check of the fuel sending unit at a repair shop I am encountering the following new issues:
- Error code P1601 (communication errors)
- Lumpy idle which evens out after ~30 s
- Braking at 30 mph results in a sudden drop of the front end by about 2 inches. It feels like hitting a pot hole. Very scary. CATS shocks acting up??
- The AutoZone alternator tests indicates that the voltage regulator is failing.
This voltage regulator failure was diagnosed at an AutoZone shop 3 months ago, but a check at a Jag dealership found no fault with the alternator.
I read threads about these individual problems, but not in this combination. Any suggestions would be greatly appreciated.
Thanks,
Stefan
2003 XJR
2002 XKR conv
Thanks,
Stefan
2003 XJR
2002 XKR conv
