Suddenly running rough - codes
#41
#42
For the 2002's the owners manual "vehicle care" lists the plug:
NGK PFR5G-11E For both NA and SC engines.
I do not know if the earlier (First) V8 engine used a different plug --- so that could be a confusion if they do .........and someone is just looking at "Jaguar V8" -- but this is only a guess.
My memory is not clear when they went from AJ 26-27-28 and exactly when the steel sleaves started ..... not sure Jaguar knows![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
Do you have your owners manual?
#44
#45
Just went on test drive - running sweet again. Now plan to let it cool and replace the rest of the plugs. Who knows, might get smoother yet.
As far as engine rebuild - not even gonna think about that.
Rebreather/Pcv - is that the little "tube" that's on the driver's side toward the front of the engine, kinda on top? The one I read about people cleaning out with a drill bit. (Can you tell it's time for me to buy a manual - or get a different car?!)
#46
Received 2,192 Likes
Steve, from vin 853935 and up take iridium plugs, before that platinum.
now lets see if you have the noise. I cannot see that anything you did would cause a knocking issue.
Use a 3/32nd drill bit by hand, and by all meens be carfull disconnecting the tube since its plastic and very prone to breaking
#47
Started it BRIEFLY.
Very rough - tap tap tap sound (probably four per second, very regular/rhythmic)
Shut it off immediately.
Next call is AAA to tow it in. Feel free to share your thoughts/condolences/sympathies.
Not looking good. Wishing I'd just left well enough alone after changing the first two plugs.
Brutal - my VIN doesn't look anything like the number you posted - mine ends in YLF06893
#48
#49
'the old are overall about 1/8 inch longer. "
Where is the difference?
Is the difference from the hex portion to the connector tip?
If so, perhaps the coil is not able to seat correctly on the new shorter plug and you are hearing an arc between the plug and coil.
Say your engine idles at 700 rpm. Every cylinder fires once for each two revolutions. There are 60 seconds/minute. (edit: it did say once for each revolution - but nobody caught it
Therefore,
750/2/60 = 6.25
Each cylinder fires approximately 6 times per second at 750 rpm.
If one is arcing you would hear about 6 arcs per second, and if 2 then 12 arcs per second, and so forth.
What are the brand and number of the old and new plugs? All of the manufacturers have application books that specifiy all of the important dimensions. It might also point out whether the old plugs are even the correct ones.
side note:
It does not apply here, but there was a remark earlier that differences in length do not matter. In fact it does. If the difference is in the thread length, it will expose either the plug thread or hole thread. Carbon buildup on either one can cause pre-ignition. If the difference is in the seat to firing tip, then a shorter dimension can cause fuel shrouding, and a longer dimension can cause mechanical interference. A difference as described above can cause bad connections. And then there is the matter of heat range which is mostly dependent on insulator dimensions.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Therefore,
750/2/60 = 6.25
side note:
#50
#51
Steve, to rule out the plugs, especially the length difference, I would just take an old one up to NAPA or Autozone, and get identical ones, NGK irridium are very good plugs. Since the coils are a standard length when secured, it makes more sense that a shorter plug is going to cause a gap where plug/coil are supposed to mate. Losing $30 on four plugs is worse than the damage this could cause if ran under that scenario long.
#52
#53
At this point the shorter/longer thing is moot. It's at the shop. Verdict expected Monday.
And remember - two of the new shorter plugs worked fine and smooth before I finished the bank. So I'm doubting size matters (in this case.)
Having said that, I still have no explanation for why, when it started it ran REALLY rough - probably would have stalled if I died shut it down immediately - and there was a distinct tap tap tap in the short time it was running.
#57
the first thing to please do is to invest a small amount.......I moved to CO 5 months ago, my car ran fine for 2 weeks I have a 99 XJ with almost 200k miles...never a major problem.
I took it to so many places and they wanted anywhere from 1500 to 3000 to fix claiming it could lead to a catastrophe. mine was a no 2 cylinder misfire and I needed a new set of heads.
I've had my car since it was new and I know it like the back of my hand...I take care of her and she takes care of me.......I took it to a place and they did diagnostics which must have been one great computer system because they told me I had a bad spark plug boot. Normally you have to get an ignition coil to also get the boot but they found a place that sold just the boots. They changed all 8 of them, dyno'd the car and it's creating 362 hp at the rear wheels and it has never ran faster. Of course the performance chip helps.
keep us posted
keep us posted
#58
Bosch 4002/FR8DPX+
NGK BKR6EGP
The stupid blister pack got in the way, but the Bosch does look longer in the gasket to nose dimension when measured through the blister pack.
speculation
If the piston contacts the ground electrode it would close the gap. Possibly shorting the plug. And, there may be residual noise from piston contact even after the initial contact.
Various application charts list the Bosch FR8DPX+ as suitable for the AJ27. But, the plug is physically longer. I like the Bosch, but maybe not in this engine. The center electrode is also completely covered by the insulator except for the tip surface unlike most plugs.
#59
So the shop says the problem is two broken air intake hoses which makes no sense - I know I didn't even touch them (unless I bumped the one up top) If I understood him right he said there was one broken "underneath" as well - which of course I was nowhere near.
Can someone tell me with certainty where the air intake hoses are located? And I haven't been told yet the cost for the part or the time - so guesstimates along those lines would be appreciated as well.
What a friggin' adventure this has become - I guess the outcome could have been MUCH worse.
#60
Okay - this seems fishy. Shop just called back - said to replace both breather hoses it was gonna cost $400 all in (roughly 80 for the parts and three hours labor)
He said they need to remove the manifold to get one of the hoses in place properly.
Bottom line - does that sound right?
