Sunroof drains
Chairman6807 (10-26-2019)
They exit the body behind the wheel arch liners. You remove the front and rear arch liners and the front drains are at the rear of the wheel arch and the rear drains are at the front of the arch. Rubber hoses for cleaning it is easier to insert a small flexible wire from the arch liners to clear the drains. Normally the drains are clear and the problem is debris at the sunroof drain openings.
Tonytonem (06-18-2020)
melby
12-01-2017 05:33 PM
