Sunroof headliner
Sunroof headliner
03 XJR - I did a search and found a lot of info on the sunroof operation and the sagging headliner, but I wasn't able to find anything that addressed my particular problem. With the sunroof on tilt, the headliner under the sunroof is sagging on the right hand side. It appears to have somehow come unhooked from the sunroof itself. I tried to push it back to the proper position, thought it might snap into place but no luck. Anyone have any ideas or advice? Is this a complicated fix? Could it perhaps be glued back in place?
yep, it's a miserable design and frequently fails. Funny, 'cause the the only thiing that ever failed on Series III was the roof motor or gear, and the only thing that failed on the XJ 40 was...well, nothing.
The added tilt feature inspired the creation of the very fragile tilt and slide mechanisms, and replacing them is alot more trouble than it should be.
Brit, at lest one of yours has a broken component on a tilt/ slide mechanism, or it would be tilting properly. Your fix is the best, no problem.
Super sport, I can help you with any of the parts if you plan on getting yours sorted out, PM me anytime. A picture to show the area of concern will save a thousand words.
BlacXJRcat
09-25-2015 06:43 PM
