Supercharger Belt wont go on
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have had my XJR apart for a while and i cant get the supercharger belt on. Its almost like the belt has shrunk while it was off the car. Is there any trick to stretching it out so it will go on? I have the tensioner as far as it will go with no avail. It is a gates belt.
It should go on quite easy. Make sure you routed the belt correctly around the crank and idler.
Drive Belt-Supercharger - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Heritage Parts UK
I remember mine being quite tight, even with the tensioner fully released. I used a 3 ft extension on the tensioner, making it easier to release, which helps a bit.
Try starting with the belt fully seated on all the pulleys except the top supercharger one, then work the belt around that with the tensioner released.
dsnyder586 (01-26-2015)
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
