Supercharger, Engine, Transmission, ECU from XJR to a XJ8
Old 09-20-2016, 04:05 PM
omgimali's Avatar
Default Supercharger, Engine, Transmission, ECU from XJR to a XJ8
Is it possible to add a 2002 XJR engine transmission ecu and supercharger and throttle body to a N/A XJ8 2001?
Old 09-20-2016, 04:22 PM
Received 8,138 Likes on 4,910 Posts
AND wiring harnesses, gearbox selector illumination module, mode switch, Intercooler pump and radiator, Engine oil cooler with pipes/hoses, Propshaft, etc.
I'll probably think of more differences after I post this.
Make sure you have a COMPLETE donor car because there will be little parts that you forgot about.
bob
omgimali (09-20-2016)
Old 09-23-2016, 06:00 AM
It is easier and usually cheaper to just sell the 8 and buy an R type.
There are a lot of differances between the two cars.
Vector
omgimali (09-23-2016)
Old 09-23-2016, 10:19 AM
omgimali's Avatar
Vector
Thats what im thinking. because i have a 02 xjr and i wanted to know if there is a way to put the engine and transmission on the xj8 but ig not.
Old 09-23-2016, 08:22 PM
With enough time and money, anything is possible.
I have a 1982 VW Rabbit that now has a TurboDiesel, Automatic trans.
There was no such thing offered here in the US but I have a bunch of dead VW Jettas and old Rabbits so I made one.
If I had an Auto Salvage yard I would probably cut, weld and fabricate some strange cars 'cause I can!'
If you have the time/money then do it. It will not be cost effective unless you consider it a hobby and just want to do it.
bob
Old 09-23-2016, 08:36 PM
omgimali's Avatar
bob
Thanks!
I was actually inspired by this video, this man made a mini-series of him putting a x308 XJR engine into his '66 SType
Old 09-24-2016, 04:20 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Ohhh, that's horrible.
omgimali (09-24-2016)
Old 09-24-2016, 07:43 PM
nilanium's Avatar
he didn't just put the xjr drivetrain in there, he put xjr wheels and the entire interior, even shoehorning the back seats in...
omgimali (09-25-2016)
Old 09-25-2016, 04:51 AM
4litre's Avatar
Agreed...sell your XJ8 then buy an XJR. You'll be much happier unless you live for tinkering on projects...
Old 09-25-2016, 11:06 AM
omgimali's Avatar
I dont need to put xjr seats in my xj8. And I don't want to sell my xj8 as my uncle gave it to me before he passed away last year. He has had the car day 1.
Old 09-28-2016, 04:11 PM
Dhighlife27's Avatar
Default Putting a 2001 xjr engine in a 1998 xjr
I know it may sound kinda dumb , but im pretty new to jags , and took on a pretty big project by putting in a new engine . Got the engine in and everything ,turns out 2001 engines wont work in 1998 jags . But the engine fit in and everything so im wondering if anyone knows of a way to make the 2001 engine run in a 1998 jaguar . And what parts i need ,like new wiring harnes . Computer ,ect.. thank you
omgimali (09-29-2016)
Old 09-29-2016, 10:03 PM
omgimali's Avatar
I think the 1998 came with the AJ26 engine and the 2001 came with the AJ27. But have you put the ECU/ECM from the 01 to the 98?
Here's a detailed explanation between the AJ26 and the AJ27:- https://www.jaguarforums.com/forum/x...inement-52292/
Old 09-29-2016, 10:50 PM
Thank you , that link really help out alot , just to be sure if i put an ecu/ecm from an 01 into my 1998 it should start up and run fine ? And do you know of anyone that has been sucsessfull doing that ?
Old 09-30-2016, 02:08 AM
JagV8's Avatar
PCM is part of immo so you'll need all the other immo modules if you change it or else reprogram. Car will go into anti-theft otherwise and may need towing to be reprogrammed.
Old 09-30-2016, 02:23 PM
You cannot just install AJ27 ECM in AJ26 cars or vice-versa.
Just swap everything in the AJ27 engine to make it AJ26. The harnesses are different as are many electronic components.
The swap has been beaten to death over the years and there are VERY complete threads and posts about the successful swaps. I have done it myself.
Search for engine swaps in BOTH X100 and X308 sections as the engine are the SAME.
bob
Old 09-30-2016, 03:39 PM
bob
Hi , i did that search and couldnt find the thread you were talking about , could you please send me the link to it . Or tell me what parts i need to replace on my 98 xjr for it to run with a 2001 xjr motor ?
Old 09-30-2016, 03:40 PM
Ok do you know how many there are and there locations ?
Old 09-30-2016, 04:17 PM
Datsports's Avatar
I think you miss read post no#15 ,read it again .
You need to swap all the sensors and loom from your old engine .
to make the car think it your old engine .
Old 10-01-2016, 01:37 AM
JagV8's Avatar
+1 follow Bob's advice.
The Search or else google should find you the threads.
Old 10-01-2016, 09:10 AM
It is EASIER to make the ENGINE AJ26 than to make the CAR AJ27.
bob
Quick Reply: Supercharger, Engine, Transmission, ECU from XJR to a XJ8
