supercharger growling, fault or not?
Hi guys,
Well ive finally got my 1998 XJR fixed and back on the road after a mamoth battle with electrical gremlins that were ALL down to the gearbox fault....Big thanks to Jim lombardi for all his advice....![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
However.......im a bit worried about the supercharger as it sounds...FANTASTIC!!.......Well, that is to say rather than the whisle id asumed it would have its got a really deep growl,(at least i think its the supercharger!?).. if it was a subaru or an impetza id just guess thats the way it should be, but it seams a bit too loud for it to be correct for a jag.......its quite loud.....the exhaust is standard and its definitetly comming from under the bonnet.
It really starts to grumble (not rattle or knock) at around 30mph and when you slow down from say 60mph to 10mph it sounds, and feels like it should be coming from an F type, however, the thing that makes me think its not right is when im going round a left hander at 30+mph, like coming off a roundabout, it goes quite for a few seconds, and i can hear the whining sound as if its getting lube all of a sudden, then when im straight and level again she growls........
I changed the supercharger oil when i got her, i remember that i sucked out very little, but it only took a small amount to start to come out of the filler so it must be at the correct level right?.....
Shes running spot on and there are no "bad" noises or feelings...so.....Is it normal for an XJR to growl rather than whistle??
