Supercharger help needed
Hello.
My supercharger needs a rebuild. It's making noise. The snout was rebuilt a few years back.
My mechanic says we need to pull it and inspect it.
My plan is to find a used one and have it rebuilt or find a used one in good condition.
Are the 98 - 03 superchargers the same?
I have seen ads showing that the 98 & 99 are different from the 00 - 03.
Also, does anyone know of a good place to have a supercharger rebuilt?
Thanks for your help everybody.
Received 1,815 Likes
You can chase a spare one down here.... Car-Part.com--Used Auto Parts Market ...they are rebuildable, plenty of kits listed on ebay. Depending on your mechanical skills, they aren't the most difficult thing to do.
A couple on site here... https://www.jaguarforums.com/forum/x...ebuild-204212/ ...and... https://www.jaguarforums.com/forum/x...ebuild-117896/
Had to hunt for this one, but I believe this answers your differences Q.... https://www.jaguarforums.com/forum/x...2002-a-199047/
Platinum XJR (08-21-2018)
Agree on the coupler, number one suspect.
That said, there are rebuilding sets (including coupler, most bearings and new oil) on the net like eBay.
The rebuilding itself is super simple, just needs a small press, almost anyone can do.
There are some instructional videos on YouTube, not for our exact model, but close enough to use the same little tricks.
We rebuilt 2 S/C in the last year upon request of the owner, including the replacing the bearings, but frankly speaking, chancing the oil and coupler should have been sufficient (both ~100.000km).
If you're sure the snout and coupler are good, it is either the rear needle bearings (fairly easy to replace) or the rotor pack bearings (the ones between the gears and rotors, need a shop with a jig and special tools to replace these). 98-03 superchargers should all interchange with no problem, I don't think there was any changes done within those years to the SC, some sites may list them as separate because the engine was redesigned around 00. You can try and stethoscope the noise to see if it's coming from the front or rear of the sc.
+1 Nilanium. for rear needle bearing. After 170x,xxx miles mine had been shot for a long time. Pretty sure all 4.0 and 4.2 units are interchanges ; there are a few differences/updates for seals and bolt on bits for latter units. Replaced my supercharger with a gen 5 unit off a 4.2 S type R. With time and age replacement the supercharger output seals and heater hoses under the unit.
I've spoken at length to a number of rebuild specialists on the abraded coating, some say yes and some say it's not important. Bear in mind it gets eaten by the engine after 100K miles anyway - it will have chipped.
I'm sure you can have them recoated by a specialist coating company - I did read the Count's comments on the tight tolerances the coating allows at least initially, but as the units wear it's not so important. I've run both and cannot tell the difference, I don't think the engine does either.
Any suggestions on a parts source for the gaskets? I'm having trouble finding anyone who shows they carry them. I haven't spoken to anyone on a phone or anything as I'm leary of miscommunication without the confirmation of an image or exploded view of the area in question.
Also does anyone have special recommendations for coolant when replacing the hoses or is peak or prestone green ok?
Thanks,.
Thanks,.
I was looking at rebuild services, specifically Stiegemeier. Looking at the list of what they do, I see that they look for rotor rub.
Is there a point where rotor rub makes the SC unable to be rebuilt?
I think I can see some wear where the rotors meet the case on the SC that I just received. Is it normal to have some rotor rub?
There are also areas where the coating has worn off off the rotors which I understand is not a problem.
It does turn smoothly by hand, and nothing rubs when I turn it, although I presume that testing it by turning it by hand doesn't mean anything.
I am on the fence right now. Do I just have this SC from the '99 installed and see what happens?
Or, do I send it off for a full rebuild?
+1 - I would also change the two knock sensors. I had to take mine off a 2nd time just to replace them
The following 2 users liked this post by rocklandjag:
Coventrywood (08-31-2018),
Platinum XJR (08-25-2018)
Thinking about the 99' SC description - try turning the pulley back and forth a half turn and feel for backlash, if it's noticeably slack, then a rebuild could be in order.
Kevlar9281
28
03-16-2016 12:07 AM
AlbBolivar
06-11-2015 03:03 PM
klfong
11-11-2012 10:07 PM
