Supercharger lag?
If it's a late model, it maybe that, due to the "cold start". It may not have met all the parameters set in the computer. Oil pressure, fuel pressure, engine speed, etc, and it has not activated the throttle, until it meets those parameters. Usually this all happens in milliseconds. And no one ever notices. Or you could have a sensor that is responding slowly due to the cold??? Hope it helps.
Jack
Jack
+1 on Jacobra's comments. By this model year you no longer have a throttle cable it is all electronic signal. Try letting warm up a little. Unfortunately without dealer level software you can't get a reading for what sensing is creating the delay. A good Indie would be capable of diagnosis.
wayne1991
04-06-2010 05:59 PM
