Supercharger oil change.
My supercharger is sitting on 150k miles and the oil has never been changed. I remember reading somewhere that Eaton recommends changing out the oil every 100k.
I've never changed the oil on one though and have no idea where to begin. Can someone point me in the right direction or upload a picture of where exactly I access the oil reservoir?
From all accounts the supercharger needs to be removed from the car to properly check and fill.
Jaguar does not recommend a change - others have mentioned that they have been told 100k or that a similar unit in other cars has a recommended change interval.
Personally -- I would not touch it. At 150k you got a good one -- I would leave it alone.
kansanbrit (05-17-2021)
The supercharger on the V8 is a filled for life internal lubrication system. Because of the confined installation, the oil level/filler plug is inaccessible and at the orientation for checking the oil level. Should the oil level need to be checked, the supercharger must be removed from the engine.
Synthetic Supercharger Oil: P/N JLM12290, Filler Plug and "O" Ring: P/N JLM12291
Personally, I agree with yeldogt; the only superchargers I have ever changed were due to physical damage.
Cheers,
Cheers,
I've never owned a supercharged vehicle prior to this Jaguar and wasn't 100% sure what maint if any I'd need to do. The only information I was able to find stated 100k changes.
How do I know if something needs to be done or checked? I was more going to change it out of a precaution than anything else.
That's actually the oil I purchased. GM Part #12345982. It was only $9 a bottle so if I don't use it it's not a big loss.
I definitely don't want to remove the supercharger though.
I found a forum thread on changing supercharger oil
Rickcusaf
Open this link to this Supercharger maintenance thread on the forum:
https://www.jaguarforums.com/forum/j...tenance-39369/
plumsauce has many postings in the Supercharger maintenance thread. Way to go plumsauce.
Jim Lombardi
Jim Lombardi
I believe the point of the forum is about information -- and the information regarding the supercharger is that it needs to be removed in order that it be properly filled.
Its a sealed system and the oil is not subjected to combustion gases.
Its like transmissions -- for whatever reason lots of people like to disregard the recommended procedure and fluid type.
You make the choice.
In recent years, MBUSA has gradually walked away from "sealed for life" on the W5A580 and is currently at 40K miles change intervals for the same transmission installed in their cars. As their installed base is larger and they are the manufacturer, maybe they just might know something.
As for fluids, there is a big difference between substituting fluid "brand" and fluid "type". If it meets or exceeds specifications, that is all that truly matters.
If substituting oil brands is acceptable, it ought to be just as acceptable to substitute atf brands.
Plumsause -- I'm not sure what you are getting at. Why is the volume of oil important -- One is a differential and the other a supercharger?
What we are talking about is a forum member asking about a component installed on the car.
And differentials do have controversy. Some people only use royal purple .. etc etc. The filling and maintenance of differentials is straightforward - it is hard to screw it up. Unfortunately, Jaguars do have leaking problems - and have more differential failures than most makes because of this.
The newer MB transmission is a 7 speed -- we can debate on the reasons what MB has different specifications ,,,,,,,,, And I have no problem with changing fluids.
But .........just because a fluid meets a minimum specification -- does not equate that it is the same fluid. Manufactures can and do design the same transmission to act differently depending on the fluid and the clutch control - they add modifiers to the fluid.
My XjR has the MB transmission -- My Mercedes wagon has the same transmission and my Porsche turbo tip has the same transmission -- I know the transmission!
But ........I don't know all that much about the supercharger. In all the years I have been gong to Jaguar events I have never had any maintenance discussions about them - they rarely fail. So I have a problem with recommending a service procedure that is different than the factory recommendation.
Its a sturdy -- well designed part -- that has no history of oil problems ......I say leave it alone.
I agree with yeldogt. I would leave the SC alone unless it was off the engine. In regards to the "sealed for life" well nothing is...the transmission in the XJR is the 5G-Tronic (also called 722.6).
It is the highest torque rated unit that Mercedes produced for a long time. They used it on all the 4matics and the AMG's such as the 2007 SL65 AMG v12 twin turbo 738 lb-ft and 604 HP monster.
It is good to drain and refill about 4 quarts and I do it every second oil change. Never had issues with this transmission and I have it in a CLK 55, C43, SL500 and S500.
On the XJR, I worry more about the 4.0 L V8 sitting under the supercharger.
I had to pull the SC off my XJR because of rear needle bearings; which are NOT lubricated from the SC Oil. I had changed the oil about a year prior. I did not notice anything to indicate inaccurate oil level.
I have a lot of friends with W body SC 3800V6 Grand Prixes, Impalas, Monte Carlos; I've never heard them talk about this remove from the car to change oil stuff on the M90 on their cars. ZZPerformance is actually headquartered in my town, and I've been to stuff they've put on and the talk is usually about couplers and pulleys, not oil change on versus off a car.
Gravedigging! There's another recent thread on this same topic with the same/similar replies.
Eatons on other cars recommend a 40k-60k mile oil interval, and they have the same guts as the one in the Jag.
The oil chamber is skinny in the direction of engine tilt, so a slight tilt in filling it when filling up to the oil port doesn't cause a significant difference in volume. I'm sure it's within tolerance.
It probably won't cause your s/c to explode if you put off oil changes (as long as it's not leaking oil), but it will run much quieter, and it will not hurt to change the oil. Also, if you've ever smelled old supercharger oil, you know it wears...
Artoman411 (05-01-2019)
In case someone comes across this, here's the link to changing SC fluid. Post's 35 & 36 are a bit simpler and more efficient methods. https://www.jaguarforums.com/forum/x...y-85828/page2/
The XJR/Merc transmissions are not meant to be run with the dipstick tool installed (search the x308 forums about this). If you're referring to the cap for the dipstick tube by the throttle body, I broke the locking tab for the cap, and reinstalled it with the locking tab removed. It's not going to go anywhere, the O-ring keeps it held in place. The locking tab is more for warranty purposes to show tampering, and unless you're expecting to warranty your 15-19 year old transmission, or it is only dealer serviced, I wouldn't worry about it.
