Supercharger oil change.
Old 03-07-2018 | 03:08 PM
Sean B's Avatar
You can get the correct fluid from Mercedes dealers, but I'm all ears on other brands that run the same specification. You can get a new locking tab from MB also, just get a flat screwdriver and pop it off to the side, the new one pushes in.
There is a thread on the XJR gearbox service with all the relevant part numbers, pan gasket, filter, fluid, locking tab etc. A nice thing to do is swap out the outer and inner O ring seals for the transmission control loom on the side of the trans. There have been problems when the seals let fluid creep up the wiring harness causing faults, new seals address this.
Old 03-07-2018 | 03:31 PM
Highhorse's Avatar
Here is the fluid level check stick (your choice)...https://www.ebay.com/sch/sis.html?_n...72.m2749.l2658
Fluid type (C&P to ebay, the 1st few are it)... Mercedes Automatic Transmission Fluid MB Spec 236.14 Red Germany
Filter and gasket... Mercedes Transmission Filter + Gasket + 13-Pin Connector Adapter 722.6xx 5-speed
Lock cap (just C&P to ebay, many results)... Genuine Mercedes & Sprinter Automatic Transmission Filler Cap & Lock Clip
This was fairly quick since I just did mine this past summer.
Old 03-07-2018 | 04:55 PM
97xj6lucy's Avatar
Sorry I was so off topic , but also thank you to all that replied and helped , it's greatly appreciated. I can't wait to get this project done !!!
mrplow58
01-21-2024 06:53 AM
duecedriver
12-25-2015 12:47 PM
Guy-Pierre Boucher
09-16-2015 06:55 PM
Boeingtravel95
09-14-2015 06:01 PM
AtholC
09-09-2015 10:07 PM
Quick Reply: Supercharger oil change.
