supercharger oil change notes
I tried to simulate the angle I used to get most of the oil out.
Also the extract and fill tubes I used.
Hope this helps some.
Dave
The following 5 users liked this post by dsetter:
H20boy (01-05-2013),
jag79 (06-20-2012),
OnebadassXJR (10-09-2018),
Platinum XJR (09-23-2013),
wasp69 (07-31-2012)
It would be interesting if someone would place a level on the supercharger top and report if this is level when the supercharger is sitting on a bench.
If so one could use the top of the supercharger to position the car tires in order to level it.
I can only assume that the supercharger is not level when the car is sitting on level ground -- as Jaguar has you remove the SC to fill it properly.
That way you could drive the front or rear tires over a suitable lift to level the SC.
However, to settle your question, you can lay a torpedo level on another suitable surface that is on the same plane ... the top edge of the valve cover.
The difference will be minimal and would not require a lift or ramps. A bottle jack would be quite sufficient.
Having said that, there are three mitigating factors:
-- any tilt of the engine is going to be higher at front and lower at back
-- the oil chamber is vertical so a given tilt will affect volume less than the same volume chamber in a horizontal chamber
-- the fill plug would be on the high side of any tilt
There are those that are happy to do maintenance as well as they can, and those who only want to follow "shop procedure".
I found this image of the Eaton SC with its snout removed on the EuroToys website. I know certain refilling requirements have been argued in this thread, but again a picture always helps me understand. It does appear that the fluid chamber is tall and narrow and therefore would not be too sensative to a less-than-perfectly flat posture when refilling. One question, which way is up?
![](http://i141.photobucket.com/albums/r64/blackjelli/59bcc90c.jpg)
Good question our engines have the S/C installed upside down as the charge is routed through the intercoolers, the coupler fixes to the cog with the dowels, means that's the snout/pulley side.
Your picture shows it as it is on the engine. I've included a picture to show the snout side.
Below the cogs is a fluid sump, the cogs pick up oil. Too much and it could impact on bearing seals, extra heat and less power transfer.
Too low and it's the same again, except the S/C snout bearings will not as last long.
The cogs give us that compelling noise.
Hi everyone thanks for the s/c oil change info I have just replaced the top and bottom ball joints and wheel bearings both sides my 95 XJR has travelled 136000klm no major probs everything works full service history I have owned her for 6 yrs or should I say she has owned ME next task s/c oil change Jimmy
#30
#31
You could also use one particular brand of aviation turbine oil, but it is not usually packaged in small quantities.
#32
An attempt to answer your query in a reasonable, logical fashion with known facts is not an assumption. If you do not wish to accept the information that is up to you. If the method described is not up to your standards, then by all means, remove your supercharger and measure to your satisfaction.
#33
Plums, I thought the information was very handy, and there is no way that I would personally recommend removing the supercharger just to drain and refill the oil. That said, if you had the blower off the car anyway, it would be more convenient!
My only doubt was where the fill plug sat relative to the level of the fluid (i.e. if they are bench-filled, I thought it might be possible that when installed the fluid line sat above the plug). In my case this certainly wasn't true, so I had confidence removing all the fluid I could, and then pumping the new stuff back in (got around 7oz in). Now maybe there is more than 7.3 oz of fluid in my supercharger at the moment, but I doubt it's far off, and I imagine it's doing a far better job than the last stuff was!
#34
#35
#36
I was in my local tool shop today picking up some fasteners, and found this,
http://www.laco.com/pdfs/product_bul.../ZoomSpout.pdf
Bought 2 bottles and I'm going to give it a try, what made me decide was the fact it has a little spout that extends enough to remove oil and install oil into the S/C - and it's turbine oil! Magic!
#37
Hi the bottle thing with extension looks like the "ideal tool" for s/c oil removal and replacement what is actually in the bottle as a Scotsman, is important, you mention 3 in one oil, in the UK in the 80,s this was a fix it all from sewing m/c to bicycle gears and chains this is not the correct oil for your Jaguar s/c not being smart just a word of caution cheers everybody love this forum Jimmy XJR95
#40
I pulled the air inlet and tried to flush the S/C oil. But the hex is not 6mm like a drawing I found showed.
From the people here that changed the oil what is the size on a X350? A 5mm hex looked right but never went in. A 4mm was too small. Since Eaton is a U.S. Company, is this a SAE screw?
