supercharger oil change notes
#41
#42
#44
#45
#46
Attached are 3 images. Looking down between the SC and the thermostat housing at the snout of the supercharger, you will see a black flat hex head screw. Loosen this and it should be easily moved with fingers.
I tried to simulate the angle I used to get most of the oil out.
Also the extract and fill tubes I used.
Hope this helps some.
Dave
Dave
Did you have to modify a standard 3/16 allen head to get into that tight fit?
#47
OnebadassXJR (10-10-2018)
#49
HEY AHHHHHH... anybody ever go in there and not find ANY OLD OIL? I've got about three different sized tubes shoved pretty far in there, and pulling back on the plunger results in no old oil. Car runs great. No supicious noises at all. Typical...
#50
