Supercharger question...
That is a damn shame cause look what I found...
VMP 2.3L TVS Supercharger Upgrade for 2003-2004 Cobra Mustang: VMP Tuning - Superchargers, Tuners, Custom Tunes, & Performance Parts
Someone(Avos) needs to look into swapping the internals of a tvs for our m112
Aye, you can't just swap supercharger internals beause the TVS & Eaton have different inlet port shapes & outlets to match the twist angles of the internal rotors. If the port timing, shape & position is not correctly matched to the rotor shape & twist angle, then you can get a situation where a particular rotor position uncovers both the inlet port & the outlet port at the same time-resulting in the pressurised air built up in the inlet manifold backflowing to the supercharger inlet.
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
