Supercharger sound
Maybe I'm just being hard of hearing or something, but I can't hear my supercharger as I drive and accelerate.
Granted, I don't know what to listen for.
I've had a turbocharged car so I know those you have a whine and then a release of the pressure, but nothing on my xjr.
Also, the car doesn't feel fast to me.
Can the supercharger not be working and not throw an error on the computer?
I just got this car the day before yesterday and can still take it b k if it's jacked up, but I'm just not sure
May also need to check the throttle cable adjustment, they have a habit of loosening off and only giving 70-80%.
Had the car at a shop today and the consensus is that the water pump and thermostat are bad.
Not a big surprise given the tsb, I have new ones on the way already.
My big question is this:
Would that have made the supercharger shut itself down?
Like some sort of self preservation type of deal?
Vikes,
6.8 is REALLY bad bro. These SC XJR's should melt your face. Check your airfiler, better yet buy a Cold Air K&N, Change Your fuel filter, You are putting Super Unleaded in this car? After you have at the very least, changed the fuel filter, airfilter, oil change, run the fuel tank down and place 32oz of MysterOil into tank prior to fill up with Super-Unleaded. then check back. If it is still not pulling mid 5's on your 0-60 time. Take the serp belt off and try turning the supercharger by hand, if that is ok, it might be a clogged cats or your drive shaft bearing freezing up?
IraG (07-19-2012)
If You have the money, get a upgraded pulley from Eurotoys, New Plugs from them, Change the read fluid and get a transmission service. I have Boral Exhaust on mine etc as well. sorry for beating this horse, but your XJR is a beautiful thing. Last piece of advice, get your self a "Code-reader"OB 2 campatible, this car will throw bullchit check engine light codes. You can turn em off yourself and save yourself a TON of money.
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
Thanks all.
I'm gonna try and get under the hood tomorrow and start doing some work.
I'll check that throttle linkage first, and then check that the sc will turn by hand.
I haven't put gas in it yet, actually, but I'll definitely stick some mystery oil in the next few fill ups.
I also plan to do eurotek pulleys and ecu tuning, as well as Mina exhaust and the Mina air filter kit plus some cooling things.
Will let you know how things go.
May do the fuel pump when I'm working on the exhaust.
Vikes,
to my knowledge the ECU's must be sent out. IMO you would be better off buying your OWN tool for the price you would someone else to do it. "one size does not fit all" you can buy a tool that will clear Codes and also change air/fuekl/timing etc for about $550.00 bucks.
If it is REALLY an effort to turn your SC pulley by hand then your nose bearing is seized, you will notice also when running that the bearing will have a flat spot, you will see this in the way the pulley turns of the nose. depending on budget you may want to remove the SC and send it out to PSE SC rebuild($900.00) Labor and r&r parts/gaskets/hoses $1,000) then put the the new EuroToyz Belt and New Plugs in it. WOW.
BUT before you do this, I would recommend seeing if the motor has an issues. Whilst the car is running, remove the oil fill cap, Do you see ANY wispy smoke? If so remove the airfilter,ANY motor oil? If yes then your rings are bad. If no? then excellent.
One thing I would recommend doing is buying a Transmission dip stick from EuroToyz ASAP. Jag does NOT want you touching the transmission . Once you have the trans dip stick, check the level, "smell the fluid, put it on a paper towell, black flakes?)Your transmission in your Jag is actually a Mercedes Benz AMG transmission. Go to the MB dealership and by 16 quarts of the fluid. ($15.00 per quart). You WILL not find a Jaguar dealer that will do a transmission service, they will tell you that it is not recommended and bla bla bla (BULLCHIT) Go to Autozone and purchase a manual suction tool, it will have the hosing that you can take and push through the transmission fill tube, push it all the way to the pan, Have any empty Quart and start sucking out the old CRAP, making sure to keep track what your taking out. Take out 4 quarts and the fill it back up wi9th four new quarts and repeat. At EVERY oil change from now on as long as you own this Jag, remove four quarts of transmission fluid, then add back four new quarts. These transmissions are $4,500 at the dealer and $3,000 grand at a mom and pop trans place. Also GET the fluid out of the rear end ASAP.
Keep me posted. lastly like I said, you have to buy a code reader for this car, These car suffer from voltage problems and the CAN circuit will cause it to throw codes for no effing reason ALL the time, clear em your self. BTW, Ebay is your best friend, NEVER buy anything at a Jaguar dealer EVER.
best
rlover
best
rlover
Granted, they usually fail such that they are at full boost, but if they stick OPEN, they never have boost.
Just a thought.
Rlover (11-12-2011)
This could be something as simple as a failed Bypass Actuator. The SC pumps away ALL the time, but when boost isn't necessary it just pumps in a circle through the bypass. (see attached) When boost is needed, the actuator closes and forces boost into the charge air coolers and engine.
Just a thought.
Just a thought.
Will do more checking if it doesn't seem to be doing anything after I get everything back together.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Just a thought.
Just a thought.
