Suspected key problem - no start
Greetings all,
I am afraid this is another "no start" thread. I have all the common symptoms with my 1998 xjr:
This problem used to be intermittent i.e. if I leave the key in the ignition on pos 2 for a few minutes, suddenly it would spring to life (electronically speaking) and be able to start. But now it seems to be permanently dead!
The things I have checked so far are:
Thanks in advance.
- engine fault
- trans fault
- abs/asc fault
- incorrect part fitted
- and so on
- Battery - substituted for known good battery - no change
- All the main power dist relays substituted for known good relay - no change
- Fuses checked, but only by visual inspection
- Main power dist studs all checked - 12 v at each one
- J GATE illumination module removed and visually checked - no obvious signs of burnout or bad connection
- Inertia switch not tripped
- Ignition barrel transponder coil replaced with new.
- Spare key - also does not work
Thanks in advance.
I think the KTM only comes into play when you're going to start the car? I'm not 100% sure on that though.
Is there a difference in anything between key pos 1 and pos 2? Then it's probably not the ignition switch.
Do you have the workshop manual and electrical guide for your year? Multimeter tests will save you a lot of time if you approach things logically, breaking down by subsystem. Get familiar with the power distribution schematics, and the ignition switched ground (sections 1 and 2), start at top most level first. Check battery connections, and the high power fuse. Check that the fuse boxes that are direct to 12v are indeed at 12v. Switch key to pos 1, make sure the correct fuse box(es) is now at 12v. Switch key to pos 2, same thing. If you see an entire fuse box that's not powered on, there's your culprit. If there's no fault there, move on to checking voltage levels at each fuse.
Another very simple check, before getting to that, check that both connections at the gauge cluster are fully seated. Disconnect and reconnect them to be sure. These can cause a lot of problems if they're not secure, and they don't always sit in tight. Make sure to disconnect battery for at least 1 min before doing this, to be safe.
avern1 (02-18-2021)
Thanks for the help with this.
At position 1 nothing lights up, but this at least cancels the alarm. At position 2 some lights come on the dash and the message screen states startup checks - although the CEL, brake check lamp etc do not come on. All auxiliary stuff works eg. Windows, horn lights, seats etc. AC does not come on.
I have checked volts at the ems relay pins: 12 v on pin 2 0v pin 1, 12 v on pin 3. Ign pos relay is 12 v pin 1, 0v pin 2, 12 v pin 3. In the control module relay box, all relays read 0v pin 1 & 2 & 12 v pin 3. (all with key in pos 2 btw).
Also canbuss checks are good, i have 60 ohms between pin 6 & 14. Voltage check was dodgy though, with the ign on I measured only 1.3v between pin 14 to ground & 2.3v pin 6 to ground.
I should make a correction here: the ign + relay has 12 v on pin 2, 0v on pin 1.
I am not making any progress with this. I still cant rule out the key itself , but the instrument cluster is suspicious - why do the "battery check", "brake check" and "CE" lamps not illuminate during the start-up checks? Or is this just a symptom of immobilisation due to the key not being recognised? If the IC is fried, would that not show up by performing a resistance test on the CAN bus?
Ok I found the problem.
The symptoms I described are classic symptoms for the inertia switch being tripped (as stated in a trouble shooting PDF found on this forum). Although I checked the inertia switch several times, I never thought to disconnect it. Live data from the BPM was showing the inertia switch to be at "1" i.e. off in Jag logic, so I decided to disconnect it, to see what effect that had. So it transpires that the cables had been broken or fried, such that the inertia switch was not connected to the loom anymore. I simply twisted the broken leads together in the loom and the car fired up like nothing had ever happened! (I have now repaired this properly, such that the switch still does its job)
Moral of the story: be careful who you select to perform welding jobs on your car! Just prior to these troubles I had some serious welding/fabrication done in the floor pan area (both sides) - you can see where the heat has melted the inertia switch connector, so this was almost certainly what caused the damage.
my 2003 x type's key is turned and all lights come up but no start ....reattempts 5 to 10 times and it starts, but not always and sometimes requires a jump. Was tolerable for over 1 year as it only took 3 or 4 turns on average a couple times per month. Now it is every day. Starter Batt and alternator (which is less than a year old) all test good. The cruise not available comes on sometimes once the car gets running then disappears after 5 minutes or so. I have heard that sometimes is related to low voltage, but like I said Alternator is good. Engines does sound a little rough but then smooths out..new spark plugs less than a year old. Car has 140k miles ...Have not tried spare key, car is a mechanics and they cant ID the problem..any help on this puppy that may help me and the author of this thread?
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
motorcarman (Today)
Sonspit
05-25-2015 03:57 AM
jagdriver
03-30-2008 09:01 PM
