Suspension making noise...
Hi guys,
My 98 vdp has started to make a clunking sound from the front suspension over sharp bumps. It only comes from the front of the car. I suspect some bushings, but which ones...? Am I on the right path? I notice on the drivers side the bushing that is visible while the hood is up is starting to crumble, while the passenger side is fine. This leads me to believe that there are other parts besides these that need to be replaced to get rid of the noise.
What is usually the first part to go on these regarding the front suspension? The car has about 68000 miles.....
Thanks for your help in advance
How do you replace just the top bushing that is visible under the hood without replacing the whole part? Is it not possible to just take off the bolt, put a new bushing on, and put the bolt back on or am I totally off track?
The bushings you see in the engine bay are the top shock absorber mounts. Jaguar sells the mounting and the bushing as one part (a different one for each side of course) but there are some aftermarket suppliers of just the bushings themselves if you have the tools to remove the original bushing from the mount and press in the replacements. The OEM parts are quite expensive, but I had them replaced and that helped with noises I was getting. I later replaced the anti roll bar bushings and control arms. It is still a bit noisy but not as bad as it was.
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
02jagstype
09-04-2015 08:20 PM
