suspension mount damaged
My son accidentally drove into a curb that has caused some suspension damage. The front lower wishbone mount was pushed back about half an inch and now the whole suspension is back 1/2" due to bush movement. The sump was also dented on. Otherwise, no other damage and car drives OK.
What suggestions does anyone have to push the mount forward again? I was thinking that I could use some hydraulic jack to push it back. Tough to do without lifting the car off the ground.. Is this something I should attempt or should this be a body shop?
I do most of my own repairs
Dave
Dave
Dave
Dave
By the sound of it, it's a bit more that just pushing it back.
Considering the design of the front suspension is meant to insulate the cabin from road noise, there are a number of factors in play here.
With such an impact, I would suggest that it has also damaged the subframe to body mounts on that side.
The front one is a 'V' design and is easily sheared.
The rear of the subframe is mounted in a large circular bushing which can become crushed.
IMO....this is a job for a competant body shop.
Of course, you can take the cost out of his hide later ;o)=)
If you want to keep the job a reasonable cost, strip and rebuild the corner after it's been on an alignment jig. Quality 'automotive rectification' or body shops have something similar to an orbital jig. A wonderful devise that puts the bent parts back to spec' - shade tree might do the same with a porta-power hydraulic ram and deft work with a bfh...of course you won't know it's right until you have a laser alignment of the car's front suspension. If it's out of spec' then the time was wasted.
It's piece of mind to have it done correctly first time. Then give your son the bill in his Christmas card
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
